VSS, speedo, or ???
VSS, speedo, or ???
Hi, I converted my Getrag 2WD to 4WD, using a donor truck. I put on the 205 and now my speedo runs less than half speed? Does anyone know what color the plastic drive should be for a 3.54? I swapped out the 90 deg. adapter and it's the same? I don't know where to look next? It's always something, Thanks, Artie
Not the truck in your sig right? If you bolt the VSS directly on the speedo output without the ratio adapter the indicated speed will be higher, likely still not right tho'
Yep, it's in the sig, 2nd truck, I know the vss sevo is just an ac sine generator, and I need to look to be sure that the only circuits are the two wires and nothing to do with a ground for a "neutral"?
jesussaves
07-18-2009 05:45 PM
southpawslingr1
07-28-2008 07:53 PM
