Valve covers??
Valve covers??
Is there any little bits of info that I should know before I remove my valve covers?Just wanna clean em' up a bit and wanted to make sure its as straight forward as it looks. Torque #'s etc.
1st Generation Admin
The bolts go to 18ft/lbs.
You should be able to remove the rubber gaskets, wipe all associated surfaces clean, and reuse the same gaskets.
If you feel you must have replacement gaskets, do yourself a favor and get genuine Cummins gaskets (grey in color). Others (black in color) do not last anywhere near as long.
There are rubber O-rings located under the bolt heads as well. They are purchased separate from the main gaskets.
Hope this helps.
Hope this helps.
dieselcarpenter
03-29-2014 09:21 AM
Mixer Man
08-17-2004 10:36 AM
Voss
02-11-2003 12:25 AM
