valve cover torque specs
Old 07-09-2009 | 02:40 PM
1bad93's Avatar
is thier a torque spec for the valve covers or do you just make them tight cause soon im gona be putting some valve cover gaskets and was wondering?
Old 07-09-2009 | 02:44 PM
92roughstock's Avatar
I just get them gootentite- snug enough to not back off, but not tight enough to strip anything. a good twist with your hand in the middle of the wrench should do it, unless you have huge wrists, then choke up on the wrench some more.
Old 07-09-2009 | 02:47 PM
1bad93's Avatar
ok thanks
Old 07-09-2009 | 03:01 PM
BC847's Avatar
1st Generation Admin
18ft/lbs.
Old 07-09-2009 | 03:09 PM
1bad93's Avatar
ok thanks
Old 07-09-2009 | 06:14 PM
Oldschooldodge's Avatar
It seems that almost every external bolt on our motors is 18 ft/lbs.
Joe V
06-30-2023 03:15 PM
lniemeyer2
10-24-2012 12:11 PM
91rangerturbo
08-04-2008 01:27 PM
Highrlr
07-08-2008 02:20 PM
NoSparkplugs
02-26-2006 08:17 PM
Quick Reply: valve cover torque specs
