Used head bolt issue
So I re-torqued my head yesterday, and the LAST bolt in the sequence felt like it was stretching. I couldn't get more than 110 pounds on it. (Yeah it backed off that much!) I replaced it with a "good used" bolt that was within length tolerance and rang well when dropped. Same deal. Found one more, same deal. No more than 110 pounds. Both bolts stretched about .020-.030, and didn't ring as well when I dropped them on the concrete. I picked out the longest bolt I had and torqued it to 100, and it felt like it was stretching, so I left it, and I am driving the truck. I am hoping to call a dealer tomorrow to get a head bolt from. Can I replace them all one at a time without destroying the head gasket? Really considering ARP studs after my troubles. Can those be re-used?
From: A 5th dimension, beyond that which is known to man.
this might be a stupid comment... oh well, its the first thing that came to my mind.... but is the bottom of that hole clean and not filled with oil or anything? i worry about that because you cant compress liquid.
There could very well be some oil in the bottom of the hole. Especially if it's one that goes through the rocker pedestal. Clean out those holes as best you can. Spray some brake clean or whatever cleaner you prefer down in there and either vacuum it out or use a blow gun on a compressor and wrap a rag around it to catch and prevent and fluid/junk from going elsewhere.
That is a great idea. We put oil on the bolts to make sure they go in with the least amount of resistance possible. After putting 3 more oil-soaked bolts in there might be way too much in there. Thanks Justin!
FordTrax
04-18-2014 08:47 PM
hitcb1789
05-25-2010 09:10 AM
mr. ed
03-26-2010 08:47 PM
Common
03-31-2007 10:43 PM
