Universal Parallel Flow Condenser in a 1st gen I/C??
Hi folks. LOONG time lurker, first time poster. thanks to everyone for the tons of useful information I've gleaned from here over the last few years!!
my question -- has anyone ever put a Universal Parallel Flow Condenser in their 1st gen I/C rig? what fitment problems did you have? how did you route the lines?
i am about to replace my lines, etc....and was looking at using a universal condenser instead of the stock parallel (actually a piccolo-style) for a couple of reasons (a - parallel are the most efficient, and b - i can get rid of ALL of the block-style connectors and switch to o-ring everywhere (Bouchillon sells an adapter to convert the expansion valve over to o-ring).
i realize that i can have my existing hardlines on the condenser cut and have o-ring connectors welded on, but I wanted to fully investigate this option first.
thanks for your input!
--matt
--matt
Welcome to the board. i was going to go this route myself on the crewcab when it was 2wd and running a Non-IC motor. Got part way through it and then never did finish it.
Can't say I've come across anyone who has done what you are asking about though.
I have a 1991 with non intercooled engine and I replaced mine with one from O'Reillys for my truck by part number and I got parallel flow style, after a few misshaps and a few dings, the condenser was a perfect fit.
I think I had to convert the bolt on the manifold to metric
i've been looking at the I/C version of that condenser (murray 6972) at o'reillys as well. it's about $130. i found a cheaper model from rockauto, but like you, i'd like to be able to inspect it before bringing it home and am willing to pay a little extra for local support. i've scoured the net and haven't found anyone who has dropped in a universal model. i suspect there is a reason for that besides the stock replacement. there is so little room between the grille and condenser on a I/C model....
i read through one of your threads and am planning on doing the same basic thing, sans the clutch relay. i want as many easy-to-replace hoses and a/c parts on this rig as possible, as aftermarket support for these is almost non-existent if one ever needed replaced in nowheresville. i have a small quantity of r12 on hand, and i am NOT wasting it on old or suspect parts. i figure if i'm going to do it, i might as well give it the strong fix.
Since your playing with a/c
It's been noted before, but the catalogs online all for these trucks pull up the 94-2002 expansion valve. If you want the correct one, type in "1985 dodge truck".
And then the part description will be "72-1993 dodge truck/van".
M
M
i pulled the grille off and took a good look - you can get a universal condenser under there, but some custom hardlines will have to be fabricated to route around the intercooler. probably just easier at this point to get the stock-replacement 6mm style and have the block connector converted over.
--matt
missouriman
12-03-2010 02:45 PM
