Ulsd + Cold = funky Fuel gauge
Old 02-05-2007 | 11:36 AM
haloman's Avatar
Ok guys just something to remeber out there. I have ran several tanks of ulsd with no problems other than fuel guage acted funny. I just assumed the sender was getting clean with the new fuel. The guage read accurately just would fluctate the first two tanks i ran. So on the way to class this morning I said " Ok I am going to fill up after class and I know I am good cuz no low fuel light". I pull into school and run out of diesel . Its like 8 degrees . So I went into class and my dad brought me some fuel and we had to pull start it )thank goodness I have a manual. So just a word of warning to be careful of your fuel gauge now. I know it wasn't gelled cuz I had plenty of addditve stuff in it.
Old 02-05-2007 | 03:02 PM
loch's Avatar
my rule of thumb is at 1/4 tank or 400 miles I'm looking for a gas station.
Old 02-05-2007 | 03:08 PM
haloman's Avatar
[QUOTE=loch;1339316]my rule of thumb is at 1/4 tank or 400 miles I'm looking for a gas station.]
that would be awesome if I had an Odometer that worked
Old 02-05-2007 | 04:06 PM
Tuckerdee's Avatar
Can't think of why ULSD would cause the fuel gauge to malfunction. Did you fill up after you ran out? And how much did you put in?
Old 02-05-2007 | 04:15 PM
haloman's Avatar
I didn't have time to complety top-off this morning but I put in 20 gals and my dad put in 5 gals. And when the low fuel light comes on I can usually squeeze in 26.5-27gal. But my gauge would sometimes swing back and forth a good bit.
Old 02-05-2007 | 04:27 PM
Tuckerdee's Avatar
Hmmm. Does sound like it was empty. Could be a bad connection somewhere. I didn't notice where you live, but the salt plays edited by admin with exposed wires and ground connections. I just don't see how the different fuel could degrade the actual sending unit though. Maybe it wore out from not enough lube!
Old 02-05-2007 | 04:51 PM
Ace's Avatar
Ace
If it's like the senders I'm familiar with, it's basically just a variable restistor that slides back and forth with the float. If there is anything wrong with the sender it's prolly just worn out from normal age/use. I'd drop the tank, pull it and attach an ohmmeter to see how it reads.
Why is it every time someone has a fuel-related problem they start screaming ULSD?
Old 02-05-2007 | 04:59 PM
haloman's Avatar
i wasn't screaming ULSD but I just assumed. I was looking for input from you guys
Old 02-05-2007 | 05:53 PM
ADMOPARMAN's Avatar
At 400 miles I would have been empty on the back of a wrecker for 80 miles.
Old 02-05-2007 | 10:09 PM
loch's Avatar
ADMOPARMAN 400 miles ? are you running in low ? I got 22.3 my last tank highway driving. My sisters 93 gets just about the same mileage.
haloman if your speedo works and not the odometer, its a easy fix, theres a sticky on how to do it,
Old 02-05-2007 | 10:13 PM
haloman's Avatar
Nope Neither . Good thing for my tiny tach and some calculators on the internet so I can at least have an idea of how fast i am going.
Old 02-06-2007 | 09:16 AM
ADMOPARMAN's Avatar
I have had the truck since November, 13.8 is the BEST milage I have been able to get, as of now we have no idea why. The only thing I have done to it is straight pipe it and one turn on the power screw. I bought this truck because they are supposed to get such good milage, I'm not happy with it.
Old 02-06-2007 | 11:26 AM
Blast Chamber's Avatar
Actually, it was a gelling problem that you were seeing on your gauge. ULSD gels much easier than LSD did, and the standard amount of anti-gel additive isn't enough. You have to double or even triple-dose to prevent gelling. I saw the same fluctuations in my fuel pressure gauge until I increased my additive use to a triple dose.
Old 02-06-2007 | 11:33 AM
haloman's Avatar
Thanks, The fuel got plenty this time for sure. I wonder if anyone else has experienced this?
Old 02-06-2007 | 11:37 AM
Ace's Avatar
Ace
Haloman, how cold was it in KY the other day when you had the problem, 8 degrees? Could be gelling.
