turning up a 91 cummins
Old 12-15-2007 | 07:05 AM
santiclean's Avatar
Hey guys, brand new to cummins diesels ( always had power strokes). The truck is a 91 diesel 4x4 with 200k and bone stock. i need some help(like i said i am new to dodges) with a few detailed dierections on how to turn up the pump to get this heavy weight to move a little quicker. i am not looking for any major mods just a few quick pump adjustment that would increase my preformance some. thanks for any instructions you can give me and i will let yall know how it goes!
Old 12-15-2007 | 07:16 AM
ofcmarc's Avatar
Ask and ye shall recieve!
https://www.dieseltruckresource.com/...d.php?t=102027
Lots of good info in the sticky. Go ahead and spend some quality time reading in there.
Welcome.
Old 12-15-2007 | 03:33 PM
97catintenn's Avatar
That should keep him busy for a few days.
Welcome to the site!
Old 12-15-2007 | 04:26 PM
G1625S's Avatar
Welcome to DTR! Head over to the user CP (upper left of the page) and fill out your signature so we know about your rig and location every time you post.
Old 12-15-2007 | 06:36 PM
santiclean's Avatar
pump tune
tell me again where is the power adj screw on back of the pump? dont see a plastic cap. only the rubber cap with the breather/drain tube.
Old 12-15-2007 | 06:41 PM
Look lower and more towards the engine. It's a tin cap.
Old 12-15-2007 | 07:53 PM
santiclean's Avatar
found it! i unscrewed the whole bolt marked the stock location and cut the weld spacer off with a dremel, put back on and tured it in about two turns and had little to any smoke. the power increase was very noticable but i noticed my passing gear is not comming in (kick down). just got the truck and it was not working when bought. any ideas on the trans?
Old 12-15-2007 | 08:58 PM
flashgordon's Avatar
As has been said before, you need to fill out your Signature so we know what you have........auto? 3 or 4 speed. ..............Help us so we can help you better.
Flash.
Old 12-15-2007 | 09:04 PM
Sounds like you need to adjust the TV cable. There's info in the sticky on how to do that.
Old 12-16-2007 | 08:17 AM
santiclean's Avatar
I have done the power adjustment on back and the recomended smoke adjustment so far.(hardly any smoke at stand on it throttle) i am going after the star wheel today and adjust the idle down hopefully. the no kick down problem hopefully can be found also. it shifts too good all the way to overdrive to be too much wrong.
Old 12-16-2007 | 08:22 AM
Your shifting problem is only with OD? Look in the sticky for info on adjusting the TPS, that will straighten it out.
Old 12-16-2007 | 09:05 AM
santiclean's Avatar
no passing gear (kick down). shifts fine all the way through o/d, but when you stand on it, i get no kick down for passing gear. runs great at all shift points, very smooth, just wont down shift out when floored. thanks for the help so far...
Old 12-16-2007 | 01:44 PM
91.5 beater's Avatar
There is a kick down cable with all your cables behind the i/p, make sure they are all on there, I have had that problem before and it was that the kickdown cable was off, it went to the hardware store and bought an "e" clip and re attached it. Hope this helps good luck with that truck, you got oner of the good diesels that you can't break, also if your truck is 4x4 it is a w250 not a
d250
JoeDiesel
01-16-2011 10:03 AM
b1984
02-10-2009 05:30 AM
bkay
12-12-2002 05:22 PM
boughtadodge
11-25-2002 08:21 PM
Quick Reply: turning up a 91 cummins
