Turbo Upgrade Recomendation?
Hey guys just got some pod injectors for my truck. Looking for a recomendation on a turbo to use with the PODs. Im sure the HX35 I have now wont get the job done as far as the most hp i can get out of this setup and keep the EGT's reasonable. So what would you fellas recomend?
Thanks
Thanks
The truck is just a toy, No towing or anything like that. i plan on hookin it to the sled next season and will be the ocasional street cruiser. dont care about smoke, milage or any thing like that. Just performance.
I have read up on the Hx40 but ive herd that you should not bark them due to the fact that the shafts can break, and since my truck is a 5-speed i dont know if that would be a good choice or not. What do you think?
you probably wouldn't have any problems with barking it if it has MWE. doesn't PDR's super 40 have the upgraded shaft? hence the "super" 40.
It probably would not bark under normal driving conditions. I meant it might bark at the end of a pull, or if you have to jump out of the throttle while pulling.
he351(stock turbo off 04.5-07 5.9 cummins) is a great and cheap upgrade! spools really quick! and cools very well! I just put one on my truck and love it! I am runnin 40 lbs with my stock sticks and it stays under 1200. Its a great upgrade! it would be great for a run around, toy truck!
isn't the he351ve the variable vane turbo? One of my neighbors wanted to try one of those turbos on his 96 p pump 12 valve. Let us know how you like it and how it works, don't you have to figure out how to electronically control those?
