Turbo question what do I need for replacment
Well I think my turbo is going south for the spring. The PO had changed the origninal turbo to a 12cm and the wastgate is non functional. I love the set up of the current turbo and want an exact replacment. How or what do I order. If he changed it from an 18 to a 12 did the housing only change? Where is the best place to order a Reman or New turbo in PA, or online. Thanks I will get all the numbers off the housing also. Please I need help.
No, it's not a Banks. It is a Holset housing, but the numbers are very unclear on the number plate. I am going to check the housing for marks shortly when I pull the intake hose off. I can check it by moving the turbine shaft back and forth and in and out, correct?
i was thinking it was a banks power system because of the 3 1/2 inch exhaust and housing, i've seen one with stock compressor housing.
move the shaft, and turn it to see if it touches anywhere.
knc77
01-04-2011 05:47 PM
Conn
08-04-2005 06:38 AM
