Turbo nut torque?
Turbo nut torque?
I got the HTT stage III, and I have the 6 point nut which calls for 150 in lbs torque. I don't have an inch lb torque wrench. Is 150 in lbs the equivalent of 12.5 ft lbs? Any advice?
if it's a short adapter, it will not change the torque output.
12.5lbs should work alright, but I wouldn't use a big wrench! IE using a 75ftlb wrench you'll be more accurate at 12.5 than using a 250ftlb wrench!
6BT12V
07-31-2012 05:11 PM
Clane
06-02-2012 03:31 PM
Firstgenfanatic
05-14-2008 06:17 PM
1stGenBikeHauler
01-25-2003 12:31 PM
