turbo number
turbo number
hey guys, My truck is done at the body shop. Its time for more power, i know you guys have prob done this a million times my goal is to make 300-350 Hp, this truck will pull my drag car around and see the street a lot , When i read this form it just makes my head spin, I'm scared I want to make this truck KICK ***!! so i want to have the right parts on the truck the frist time. When you guys talk Turbo i need help to choise the right one. the truck is a 5 speed 4x4, the guy i bouth the truck from rebuilds 2nd gen trucks, I called him he has all kinds of turbos, I told him I would like to get a HX35 or a HE351, his name is Luke, Luke said he does not know what the hell i was talking about, he says he needs the Dodge part # for the Turbo, then he could help me, I ask him what the price would be, he told me $100, i almost **** my pants from reading this form, thats cheep for a turbo, all i could think of was buying all the turbos off of him, and putting then on Ebay. I was thinking Exhaust.Fuel Pin,Injectors,water Meth: THANKS EVERY ONE
in this order: pyro, boost, and fuel pressure gauges, low pressure lift pump, cold air intake, HE351, 4" exhaust, bigger injectors, 366 spring, fuel pin, pump and timming tweaks...all of that in about that order should keep your truck safe and making the power you want. i didn't do mine in that order but ill have dyno and 1/4 mile results after this weekend to let you know for sure
If the truck won't see any towing...
6X.016 injectors
62/71/14 S300 turbo
Upgraded lift pump, a low pressure piston lift pump will work
4" exhaust
Clutch
DennyT Fuel Cone and Pump tweaks.
And of course, before any fueling modifications, you need gauges.
Pyro, boost, fuel pressure, and transmission temp are what I recemmend.
6X.016 injectors
62/71/14 S300 turbo
4" exhaust
Clutch
I see you want to tow your drag car. Do you want to be able to use a 300 HP while doing that? Your answer to that question will determine what you need to do. 300 towing HP is going to require an intercooler, bigger radiator, and at least an HX-40 turbo.
Don't put any money in injectors, you can make 300 HP with the ones you have.
MoparRiggan
09-29-2005 08:39 PM
Bushy
07-16-2005 01:50 PM
