Turbo-to-manifold Gasket
Is this the correct part number for the gasket that sandwiches between the exhaust manifold and turbo:
FELPRO # 60928
Also, is this gasket the same in both 1st and 2nd Gen.??
Thanks.
2nd Gen should use the same gasket. I believe the ISC and ISL engines also use the same gasket. Even non Cummins engines that use the same size flange (most of the turbo's have a standard flange of several different sizes) will have a gasket that works. 3901356 is the Cummins number for that gasket and 3709861 is the Holset number. If you have a cross reference list for felpro you can check your number against these Cummins numbers. Hope that helps.
I found a gasket.
A little different in that it has one large opening, instead of two small openings; other than that, it is the same.
It is in a bag that has Chrysler part# 05018525.
The gasket, itself, has stamped # 3919369 WEK USA.
One more question:
This gasket has a formed ridge, around the perimeter of the hole; does this ridge go next to turbo, or next to manifold, or does it matter??
Thanks.
I found a gasket.
One more question:
Thanks.
Doesn't matter where the ridge faces.
Thanks for the info.
Stuff like this can be a small hassle, or a long wait, or drive, when living in these little Hooterville towns.
jmccart
14
07-31-2008 11:46 PM
