turbo flange to manifold steel gasket
are these reusable? other than going to Cummins, this is tough to find in my area. No way on the dealer. I tried to get the hood insulation fasteners from the dealer and they wanted almost $4.00 a piece for those!! Anyway, I can imagine what they want for the steel gasket.
I've had the turbo off three or four times, just resued the gasket no prob yet. The manifold and turbine housing are realtively soft, should seal up if the bolts are tight.
When I had cause to remove the turbo, in order to get my A/C air-box off and back on the fire-wall, the metal gasket was in pieces.
I borrowed one from a friend and ordered five new ones from Scheids Diesel, about four bucks apiece.
The one I originally had on the engine had the divider between two seperate holes.
The one I borrowed was one big open hole, with no divider; in use, I can't tell any difference.
The ones I got from Scheids are like the original, with two seperate holes.
As cheap as these are, it would pay to stock up.
banks twinram
13
08-16-2010 02:47 PM
BigJohnston
06-01-2009 12:42 PM
jmccart
14
07-31-2008 11:46 PM
