turbine housing interchangability
would a turbine housing for an H1C/HX35 non wastgated fit on an H1E like the one for sale here
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
id like to buy this and then go to a 12 or 14cm turbine housing
also is it true that the HX35 flows more air then an H1C thanks id check compressor maps but i have never found any for any holset turbos
AFAIK, the H1E is bigger all around. It's like an HX-40 but older. :eyecrazy:
The H1C is not real good at high boost and low airflow, it surges pretty bad. I found this out the hard way when I put a 12 cm housing on my H1C. The WH1C and HX-35 have MWE slots that solve this problem.
High Tech Turbo sells a bolt-on compressor housing and pinwheel set for the intercooled H1C that makes it a hybrid of the H1C and H1E.
