TST KDP and seal kit
I should be receiving my KDP repair kit today, the only issue being that I ordered the kit for '94 to whatever because I didn't see one specifically for the 1st gens. I am assuming it's that same though, anyone know for sure????
No they are not the same, the first gen is a steped design and the 2nd gen is a flat plate. This is a first gen. The rest of the kit is the same though and you could make your own tab.
1st Generation Admin
Or you can just bend up a piece of heavy coat-hanger wire like so ~
And slip that boy in there like this and be done with it ~
Some have been successful at simply using a punch to displace a bit of metal adjacent to the pins hole.
What ever works.
Don't forget to check the other timing case bolts while you're in there.
What ever works.
This is probably a stupid question but can that dowel pin work out the other way?Do I understand that the deal with the pin is it works out an falls into the gears and engine dies a horrible death? How often does this happen?
If you are going in to the front case be sure to address the 5 bolts that hold the front case to the engine - one of which is the KDP bolt shown in the picture. I've seen the damage they can cause when they come out - just as bad as the KDP.
Bob
Bob
In a side note, I may jump the pump gear a tooth while I am in there.
Wouldn't loctite also work for the dowel pin?
With the proper cleaning of all involved surfaces prior to applying, I don't know why not.
The pins job is to resist shear forces. As such, we don't really have to worry about any thing pulling on the pin (tensional forces).
As long as there's a good tight fit of the pin, you should be good to go.
offroad
03-16-2008 06:56 PM
