truck shakes?!
Old 06-24-2008, 10:54 PM
1993rollincoal's Avatar
the violent shaking is your shackle busings on each end of your leaf springs. When you hit a bump it cause's your axle to move back and forth via the worn busings. Get your springs rebuilt.
Old 06-25-2008, 02:46 AM
Hot Dawg's Avatar
OH MAN, sounds like you have the "DEATH WOBBLE" its caused by bad king pin bushings. Let me guess, it only happens at speeds around 20-40 MPH and you never know when its gunna do it??? The "Death Wobble" is a Dana 60 thing, us offroad guys see it a lot because bigger tires wear the king pin bushings faster.
Old 06-25-2008, 07:09 AM
powerrammaster's Avatar
King pins shake with or without braking. Diving to one side would likey be a caliper grabbing/partially seized piston, pulsation thru the brake pedal is warped rotors.
Old 06-25-2008, 06:20 PM
big stinky's Avatar
x2...
This happens with any front solid axle that has loose knuckles on the axle.
King pins fo sho.
Old 09-14-2011, 05:08 AM
KRB
KRB's Avatar
How bout an update?
Originally Posted by bjerauld
the times it doesn't shimmy it stops nice w/o any pulsing... other times if I let go of the wheel while its shaking it just goes back and forth like mad! I have noticed it can be set off by hitting a bump during braking... odd.. but never when just driving normal.. only under braking.. sometimes..
I know this is an old thread but your description is exactly what mine does. Shakes back and forth when braking - sometimes. Can be made to go away if steered left or right. Can't feel it in the brake pedal, only the steering wheel.
So, bjerauld (if you're still out there) what was the final solution? Tie rod ends? rotors? Kingpins?
My tires are new, just replaced the drag link, rotors were turned a couple years ago. Box is tight, no frame cracks. Truck has about 175K with no hard service.
DodgeDawg2500
02-24-2007 09:21 AM
Timberman
13
08-07-2006 11:43 AM
IntakeRacing
05-25-2006 10:39 PM
Hoss
20
12-08-2004 09:40 AM
bwat4
02-08-2004 09:10 PM
Quick Reply: truck shakes?!
