truck dies after hard acceleration
Truck died today for the second time. It runs fine, but when I accelerate in a hard pull and get out of the throttle quickly, the truck dies. Then I have to pump the hand primer and crank for a long time with it wide open until it finally starts to hit on a couple cylinders. Then eventually it clears up and runs fine. Has anyone had any issues like this before? The only recent change is the piston LP. Any help will be greatly appreciated.
1st Generation Admin
It's common for our trucks, when turned up, to do this.
Winding it up at wide-open throttle while under load, then side-stepping the throttle (snap closed) has some of the cylinder's compression stroke, back up into the injectors . .. basically binding them with air. The only fix is to loosen the injector feed lines, at the injector and burp the air out. Doing the first three injectors is usually enough to start the engine. It'll stumble a little till the others are cleared of air.
The only way to prevent it from happening is to learn to roll-off the throttle instead of side-stepping it.
I have had the same problem just not as bad mine will stay running and clear up on its own. For some reason I always forget to roll off the throttle I will learn someday.
92smokin blacky
09-14-2011 08:44 PM
what
11-13-2007 11:06 AM
xfeastonarsex
02-05-2007 05:35 PM
supercharger
11-20-2004 08:59 AM
