Trashed pump and clogged injectors
Old 09-21-2004 | 09:03 PM
mhuppertz's Avatar
Is it likely that my injectors are clogged with junk from my trashed VE pump?
Mark
Old 09-21-2004 | 11:58 PM
Stomp's Avatar
Ok I have read your posts about your fuel pump problem. To be safe I think you might want to have you injectors checked, but the way you described the problem it sounds like a seal went out out of the pump. We need more info.
Stomp
Old 09-22-2004 | 09:32 PM
mhuppertz's Avatar
I panicked and bought a reman out of Oregon, and got a set of POD's off Ebay for a really good price.
Is there a locating pin I need to worry about?
Thanks!
Old 09-22-2004 | 10:05 PM
Stomp's Avatar
Here is a link to explain how to change the pump. I hope this helps. Just keep scolling down and it explains it in detail with pictures.
http://dodgeram.info/tsb/recalls/605.htm
Stomp
Old 09-22-2004 | 10:07 PM
mhuppertz's Avatar
You rock!
edtyler
09-07-2011 08:02 PM
Crossy's son
01-07-2009 09:24 PM
hungabunga
21
04-11-2008 11:15 AM
hungabunga
04-09-2008 01:16 PM
mhuppertz
09-21-2004 10:53 PM
