Transfer case Mount
Not sure what you are looking for but there is no separate mount for the t-case. It just bolts to the trans and hangs there. Check my gallery, there are a couple of pictures that show the back of the trans and the front of the t-case. 6 bolts attach the two and thats it.
Are you talkingabout the tranny adaptor? This replaces the tail ofthe2wd version. It has tranny fluid circulated through it. It should be easy to tell which way the plate between the adaptor and cross member faces, by lining up the holes. The bend in the flange should be facing the front of the vehicle, to protect the front drive shaft.
brattboy
01-30-2015 05:19 PM
chw
12-25-2006 04:30 PM
