Trans pan
Trans pan
I need a recommendation for a good transmission pan for a 93 CTD auto. I can't get my dad's pan to stop leaking and he's not the greatest about checking fluid levels.
The pan is leaking. I recently replaced the fluid and filter, it has leaked since my dad bought the truck. I would like to install an aluminum pan.I've heard of the mag hytec pan's but don't want to spend $250 on a trans pan.
When it came to my upgrading my mess, I couldn't justify the expense of the Mag Hytech. Digging around in the Summitracing web-site, I found the BMM-10280 (B&M) to be the best price for what it was ~ an aluminum trans oil pan with an additional 4 qts capacity.
Check it out at http://store.summitracing.com/
Regardless, when it comes to installing the trans pan, don't super torque down the bolts as that only pinches the gasket material in two, insuring a leak. I can't remember the exact figure, but the proper torque is in the inch-pounds range.
Hope this helps.
Hope this helps.
mar67655
03-14-2009 07:22 PM
EverydayDiesel
11-11-2007 09:33 AM
MrKen
11-23-2006 03:19 PM
bostongsx
09-25-2006 11:25 PM
