Trans crossmember support
The diagonal piece that goes from the op of the frame to the crossmember support on the passenger side. If that was removed would there be any issues of the crossmember not holding the wieght? The remaining bolts would be replaced with grade 8 and lock nuts. thanks
I believe those upper brackets were designed to add controlled flexibility between the frame and the crossmember. The added brackets allow the crossmember to return to it's original location after the frame flexes and returns to its resting position by providing more contact points with less wear per contact point. Think of it in term of stress - load - wear distribution.
while we are on this topic and in this area of the truck.......does out transfer case just bolt to the back of the trans, and thats all that holds it, or is there something else giving additional support....such as a crossmember and/or bracket??
t-case bracket
there is a braket the goes form the crossmember to the t-case its only held by 2 bolts on each side. 9/16 inch bolts i believe.
1st Generation Admin
I do not think I would do it. If you think about all the torque (twist) put on the frame. All if it is held to the truck frame through the under engine crossmember and the tcase member. without the upper brace, I would not worry about the bolts so much as I would be concernes with bending and fatiguing the lower lip of the c-channel. With the upper brace you have a box. Without it you have < 1/8 inch sheet metal overlapping and bolted to < 1/8 inch sheet metal. I think it will eventually fail.
I haven't had the diagonal crossmember support (just the passenger side) on my truck for a few thousand miles now. No problems at all. I figure that if something does go wrong I can just fab up a better one.
If Chrysler Corp could have saved $10 per truck by eliminating the brace brackets without encountering any engineering difficulties you can bet your lunch they would have done so. If it doesn't fit because of exhaust interference then you need to look at modifying your exhaust and not your crossmember braces.
i was kicking the idea around about taking it out for the exhaust to fit better but i dont want to compromise the frames structural integrity.
It shouldn't be that hard to fab/modify that member to add a little bit of room. You just need something to tie the top of the rail, the bottom, and the crossmember into a triangle.
Mopar1973
02-01-2014 09:31 AM
