tranny problem
tranny problem
i think i fried the reverse in tranny today reverse is slipping so bad that truck does not back up anymore any other thing i should do since im gona be in there any ideas its an auto with od
Originally Posted by Geico266
Chances are you roasted the rear band already if it was partially applied. If you have a way hook a pressure gauge to it I would do so before you drop the pan. Going to need a 500psi gauge because reverse line pressure is pretty high, My book isn't handy right now, but at idle is should be over 120psi and WOT could be upwards of 280psi or more. There are ports on the passenger side of the trans, it is the 3rd one back from the front, you'll see the where the front and rear servo are in the trans case. The plugs are 1/8" pipe thread. You could have an internal leak in the valve body or servo.
When you drop the pan, look for debris in the pan and burnt fluid. Check the rear band and see if you can adjust it. Chances are your looking at dropping the trans to fix this, I'm sure you already figured that.
A good stock rebuilt with a good valve body should hold just about anything you can through through a non-lockup torque converter.
tranny
thanks i ckecked the fluid right i broke it and it smells burnt so i fugured something was bad with bands its in the shop right now maybe i got lucky i found a donnor truck with same tranny i think thats the way im gona go
Black Dog
12-03-2009 08:18 PM
high bid
08-02-2007 06:08 PM
ezdemon72
14
07-29-2005 10:05 AM
mikie1234
12-25-2004 12:54 AM
silverram323
24
11-09-2003 07:48 PM
