TPS fell apart
TPS fell apart
Has anyone had there tps fall apart? the top of mine came off and the thing that spinns on the throttle came out through the top, the return spring to the tps is MIA and i was wondering if there is any way to put it back together where it will work, Thanks
we have tried potentiometer two times on his ^^^ truck, we had it workin once then finished the install and it pooped out on us, any tricks or tips you guys might have??
Yeah ill try thepot. again instead of puttin 300 bucks into a tps, What is the exact pot i need and is there anytricks to puttin it in. Will my cruise control work? will it shift 1-2-3-4 or will it shift 1-2-4 , will it skip 3rd gear if you dont turn o/d off, do you have to turn o/d off when making a stop and turn the button on when wanting it to shift into fourth gear. thanks for the input
Tuckerdee did a outstsinding write up including pcitures of teh POT install :
https://www.dieseltruckresource.com/...d.php?t=142641
yo wont lose cruise if it was working otherwise.. adn oncve you hve teh pot adjusted , it'll shift 1-2-3-4....
Ill give it a try again this weekend, and is it a .5 watt and and how many ohms of resistance, ill pick the stuff up tomorro. Also what is the best guage wire to use?
I put my potentiometer in and it works GREAT!!! it was the best $5 investement that i think that i could ever put into the truck, highly recommended and my cruise control works now!!! thanks for all your alls info, this site rocks
VACHZHD
02-24-2010 12:48 AM
