Towing with a stock A518 automatic
#31
I think a 100% convertor means it is locked up, so our non lockup TC's can't quite get there.
heh heh, I have a 5th wheel camper as well. It's a 1994 Skyline Nomad 2515 Limited. It's about 26' long.
I think its actually a little lighter than my parent's Shasta 25' travel trailer. I think it will tow easier than theirs.
I towed theirs up the mountain on a couple weeks ago to test my EGT's and I worked the trans kind of hard. I have that Double Deep (+4 quarts) pan from mag-hytech on mine and I think it does quite a bit to keep the trans fluid cooler.
#32
the 91% clams are pretty much for the racers that have a LOT of power - sled pullers, draggers, etc. The 89% is what I have in both my '93s and they 'feel' like a lock-up while still allowing some spool. The 89% gig in my tug boat is getting over 300hp/620tq to the tires, and pulls 10k+ no sweat.
- Sam
- Sam
#33
- Sam
- Sam
#34
that is exactly correct - 60% is right about how the factory clams are built. As I understand, Mopar wanted to introduce the 6BTs in '85 but the tranny's weren't up to the task until ~'89, and at that time they didn't have a strong enough overdrive, hence the D61 and D71 with the 3.07 gears - that's about as good as the technology was at that time. As well, the engines...as we're all aware...are capable of making a LOT more power than the factory rated 130hp/400tq, but they were set at the lower power levels to prevent cooking the tranny's - literally.
Heat...it's all about heat, both in the engine and the tranny.
- Sam
- Sam
#36
#37
I was just rereading the posts and had this thought. Don't forget to upgrade the flexplate when you decide to do the T/C and tranny. The stock flex plate is weak. I am running a second gen. flexplate and so far so good.
#38
I've been thinking the same thing - I should have done a flexplate when I did the recent clam swap. I guess I'll likely wait until I have to pull the tranny back out.....or until the plate cracks in half....which occurs first ....
#40
flexplate question:
I have heard of guys running the factory 2nd gen flexplates............I've also heard people say they do not fit 1st gens........others say they do with no mods. Whats the scoop on this? I have heard about the 2nd gen auto flex plates being much better in construction.
#41
#43
Cosmetically, they're the same. You'ld be hard-pressed to tell the difference at first glance. But the 2nd Gen flexplate is stronger. I'm running a 2nd gen flexplate with no mods to the bellhousing or torque converter area. It bolts right up.
#44
Engine & Drivetrain A518 Automatic Transmission Complete with Cooler and all lines
oliverbutthead
1st Gen All Products
0
02-27-2015 05:21 PM
Mopar1973
04-07-2012 06:45 PM
1-5-3-6-2-4
07-18-2010 12:51 PM
2002cumTRBODSL
11-25-2005 10:23 PM
