Tow mirror suggestions for my 92?
I have power side mirrors, but they really are not good for my towing needs- my horse trailer is way too wide for them. I need good wide tow mirrors. I am not married to the idea of needing power mirrors either. My 93 way back in the day had the tow mirrors, they came with the truck stock I think- it was a dually though.
They weren't the greatest looking things on earth, maybe there is something better now for our trucks?
My 81 came with something similar to that. I hated them because they always vibrated. I replaced them with West Coast trucker junior I think the where called. No longer made the last time I checked. They connected above and below the window.
thrashingcows (02-22-2023)
Control GM towing mirrors with Dodge dash controller? - Dodge Diesel - Diesel Truck Resource Forums
This is the thread on the mirror install.
I'm still not done. I don't have a shop like some people! I'm going to move the support bracket inside the door forward, plug/weld up the holes and maybe a brace inside the door from bracket to ? if I can clear the window.
Easiest way to go is a low mount set up which I think you can still buy.
thrashingcows (02-23-2023)
I just use a set of **** slip on mirror extensions. They go over the stock OEM. I only need them when hauling hay or something else really wide that hangs over the gooseneck sides so I run stock 99% of the time and just slip them on & off as needed.
I put a flat bed on my M880 though and added the swingout type camper mirrors with the frog eyes like u2slow has. I like them but they do create a blind spot that you have to be aware of. Plus they catch branches & bushes if your driving in that type of terrain.
One of the problems I find with the style mirrors u2slow has pictured, is they do not fit through my narrow garage door.
Might not be a problem for most, but it is something I have to think about.
You can also loosen one bolt and flip them inboard; but that trick is useless if your bed/body is 7' wide or beyond.
