Torque Spec on Spindle Nut
1st Generation Admin
- After installing the hub without damaging the inner wheel seal, install the outer bearing, and outer wheel bearing adjustment nut.
- Tighten the adjustment nut to 120 - 140 ft/lbs while rotating the wheel.
- Loosen the adjustment nut 1/3 of a turn to provide 0.001-inch to 0.006-inch wheel bearing end play.
- Tap the nut lock into the spindle key-way and adjustment nut.
- Install the axle shaft, . . . . . blah, blah . .
So says the FSM under Wheel Bearing Service, page 3-33.
