Top of VE leaking fuel
Old 02-19-2013 | 12:36 AM
dan123dbl's Avatar
Question Top of VE leaking fuel
Other day after I changed my throttle linkage to the inside spot, I noticed that my ve was leaking fuel at a constant dribble while it was running. I'm not sure if this was caused when I loosened the ball joint or if it was just coincidence.
It's my daily driver and I'd like to get it fixed in the least amount of time. I'll attach a few pictures to show where It looks like the fuel is coming from. I did some searching but didn't look like it was the same area so sorry if this is a repost of something that's already posted.
Size:  168.1 KBRight underneath that large spring.
Also I tightened the top of the throttle arm a bit, and it looked like it made the leak better. It feels like it could go more but I don't wanna over tighten and make it worse.
Any info would be great,
Thanks.
Dan
Old 02-19-2013 | 12:48 AM
Your throttle shaft seals are leaking. You'll need to pull the top of your pump to change them out. Not a bad job, but a bit of a hassle to get those four allen key bolts out.
Old 02-19-2013 | 01:05 AM
dan123dbl's Avatar
Thanks for the quick reply thrashingcows!
Do you know of any bosch dealers around you? You're not too far from me.
Old 02-19-2013 | 04:43 PM
12vChapa's Avatar
Yes long allen wrenches Dont strip them out!
Old 02-19-2013 | 05:16 PM
Well I'm willing to help if we can combine schedules. You just need a Bosch DGK-121 reseal kit and a few hours.
Old 02-19-2013 | 08:38 PM
93/4X4/CREWCAB's Avatar
Make sure you change the bushings and the throttle shaft at the same time or the repair wont last.
Old 02-20-2013 | 01:22 PM
bannerd's Avatar
Yeah, from the looks of it, you just need to replace the o-ring on the index shaft. that rides the gov spring. I would do the entire pump though.. I find that once you replace one.. the rest are soon to follow.
Old 02-20-2013 | 06:27 PM
dan123dbl's Avatar
Alright thanks for the info guys. However I tightened the top of it with an allen key about 1/8th turn and now it doesn't leak at all..
Now seems like a good time to re-seal everyone on it though. I'll get a kit and maybe do a 366 spring as well, seems like it really helps with drivability.
BUFFALO_STEW
12-17-2009 03:42 PM
jesussaves
10-23-2009 07:52 PM
TIMMY22
19
12-30-2005 08:44 AM
moparsupremist
04-24-2005 02:12 AM
