took some pictures
Old 05-19-2009, 10:33 PM
alwaysonDTR
Alwaysworking's Avatar
3rd low side will probably be to high with 3.55s might want to try 1st high side
might try that,
might just run 2nd lo to be safe since i have to drive almost 150 miles there
Old 05-19-2009, 10:46 PM
Trooperthorn's Avatar
You should bolt on my 35x12.50s and run in 2 low.
Old 05-19-2009, 10:47 PM
alwaysonDTR
going to run some 285's
Old 05-19-2009, 10:49 PM
I can never remember how 285 translates into good ole' American hable'. Are those like 33s
Old 05-19-2009, 10:51 PM
alwaysonDTR
beats me, i think so there also wider
Old 05-19-2009, 11:18 PM
Best Paint (Getrag category)
pulltilbroke's Avatar
I'll be running a set of 33/12.5/16 Interco STS's and they are just a smidge bigger than the 285s
The magic crawl ratio is about 15-1
2nd low is 21.15
3rd low is 11.61
1st high is 19.91
This is all figured with an NV4500 also, so the rag shouldn't be to far off from these figures
What are the gear ratios in the rag anyway
Old 05-20-2009, 08:41 AM
apwatson50's Avatar
So how much do you have to slip the clutch to get the sled moving in 2nd lo?
Also the gear ratios in the rag' are pretty close to the nv, they may be just a little lower as I know the split between 3rd and 4th is larger than the nv.
Old 05-20-2009, 02:01 PM
Getrag- 5.52/3.02/1.60/1.00/0.77
Old 05-20-2009, 06:26 PM
It all depends on track conditions and the sled, I usually slip it a little on a tight track and on a loose track I come out under the charger to keep from blowin the tires off it and when it lights I just feather the throttle to keep traction
The ratios for an NV are
5.61
3.04
1.67
1.0
.76
Old 05-20-2009, 06:30 PM
1st high 19.59
2nd low 21.01
3rd low 11.61
For the rag
Old 05-20-2009, 10:06 PM
schamran's Avatar
That kinda looks like what my springs look like under normal conditions. I don't have a 7-spring pack though.
Old 05-20-2009, 11:22 PM
alwaysonDTR
not much just like takeing off with a load in 1st high
Old 05-21-2009, 12:17 AM
What kind of track is the most common where your at always
Old 05-21-2009, 12:23 AM
alwaysonDTR
hard and moist, only been on one dry track
Old 05-21-2009, 01:34 AM
How many times you hooked that thing now?
Most of my southern tracks are real sticky clay, they'll hold a lot of power but you see lots of breakage then our northern tracks are right in the middle of loose and sticky kind of a sandy clay. Pretty good track prep around here too only got a couple of junk tracks
Quick Reply: took some pictures
