Too much black smoke
Hoping a guru will read this post. I had a leaky injection pump on my truck so I decided to pull it and put a rebuilt one on. Truck ran great just leaked fuel. I ordered the Scheids 105 lightning pump put it on and was real hard to start. I did bleed the lines. Ran real rough idle, shaking etc. White smoke bad pure fuel out of the exhaust. So I decided to change the injectors with DFI 5X12 sac injectors. No change. I had a brand new Airdog 100 sitting around so I installed that , no difference. So I got reading and decided to advance my timing all the way to the head no difference, Then I pulled my front cover off and skipped a tooth advanced and now starts just like it used to little haze at idle but I expected that from the injectors. Sound great until I hit the throttle then it breaks up real bad Black smoke real bad. Once the turbo lights it smooths out very little smoke and puts me back in the seat. I have a s300g 57/65/14 turbo on it. I do build boost good once turbo lights up. My egts climb fast also with only 4000 lbs load.. Never had much of a problem in mountains with 14000 lbs. My truck is 1992 D250 intercooled automatic Today I put the smoke screw flush with the top in increments no real change and the star wheel was all the way down I put it about 3 threads from the top little change definitely was hoping to get smoother acceleration. Still rough on hard throttle and way too much black smoke. I have driven it about 100 miles since new pump drives good as long as i don't hammer the throttle. Thanks in advance.
89-93 Dodge 5.9L Cummins Scheids 12MM Cut delivery valves 4000RPM High Performance VE pump from Pure Diesel Power
Seems like with all the afc adjustment I did it is still flooding the turbo until it lights. I have the stiffer spring also. I am going to try to flip
the star wheel and put it at the top where it while catch the locks and see if that helps.
snowmanx
06-05-2010 10:11 PM
rguerra01
15
10-28-2009 05:16 PM
