Tips For Removing Rusted Old Exhaust Manifold?
I use Kroil on mine. Then I'll tap generously, not beat, on the bolts with a hammer to put some shock through them to hopefully loosen up the rust and I'll use an air gun on all the bolts I can. Start gently letting the gun hammer then a little more, if it moves then I might go back and forth a little bit then they will come right out. The biggest problem is getting the socket to fit tight on rusted bolt heads.
Took mine off for the first time recently. I sprayed with PB Blaster on and off for a couple weeks first though. Came off no problem. Now looking for studs when I reinstall.
Dodgezilla
11-06-2011 04:13 AM
chariotdriver
10-18-2008 10:50 PM
Neal Cassady
14
01-28-2006 08:39 AM
