Tiny Turbine Housings???
I need to know what the small turbines are for a the HC1 turbo. Obviously the most popular being the 12cm. What is available smaller. This is NOT for a cummins. It will be used on a different application that requires a very small turbine housing. If you own one smaller then this please PM me.
There was the HY-9 on the 24v automatics. Not sure if the 9cm housing bolts to an H1C, but the entire HY-9 can be had for about 200 bucks pretty frequently....
Yup, sure is, and it'll make you're truck a LOT more fun to drive. It'll make it real easy to surge the turbo, so you'll have to watch the loud pedal application down low in the revs. Everybody should try the 12--especially on a 5 speed
After owning a 91 5sp with a 18cm housing and now driving my 95 with a WH1C 12cm w/g housing I think about how much better my 91 would have been with a 12cm housing... If you can get a hold of a 12cm w/g housing do it!!!!! or even a 14 non w/g would be pretty good over the 18 or 21.
mooktank
07-24-2006 12:37 AM
