Tiny injectors
Tiny injectors + used motor oil
are there any tiiiiny injectors you could get to up mpgs to about 23+??
Alsoo, can you run Straight (coffee filter strained) used motor oil thru the gas and have it work? or is it like 1 gal MAX
You would lose a lot of power. And by that time it would use more fuel getting your truck up to speed. If you want to try it out just back out the fuel screw. It would be like doing the same thing.
I`m no expert but... seeing as how a diesel is throttled by fuel quantity not air (like a gasser) injector sizing has alot less of an impact on mpg`s. You could have showerheads installed and as long as you don`t call for the HP the pump won`t supply it. It`s the reason diesels get such good milage as it is, the ability to run a 100to1 A/F ratio. As far as the WMO, I think you might have to be your own R&D lab to figure it out, personally if I was going to put WMO in my truck I would filter it alot finer than a coffee filter.
Lol, cowboy in a geo.. Nah
Yes.
I know, i was trying not to smoke it. And, that meant driving REALLLY lightly, so mpg+++
I get 20MPG with POD's and the fuel screw all the way in, but I have to drive it carefully and coast down long hills.
Auto... Darn fuel. Whys it gotta be so high??? (pretending to be ignorant, not bringing Europe up)
If you want to detune the truck, don't buy it. With twins it will not be a good driver with small injectors. Buy a truck that's closer to stock if you want high mpg. A D250 is the best way to go if you want fuel economy.
zapata
04-25-2006 02:08 PM
