Timer for block heater: How long?
Old 12-13-2010 | 03:49 PM
Subliminal's Avatar
Hey folks,
Just wondering how many of you use a timer for your block heater and how long you let it run?
I leave the house at 7:30 and was thinking 5:00 might be a good time for it switch on. If I don't plug it in and it's ~20 degrees...I don't really get heat on the way to work...and that's annoying...but I ain't made of money, either!
Old 12-13-2010 | 04:01 PM
Rickcher's Avatar
I use a timer and have it set to start two hours before I leave and it's warmed up pretty good when I start it. (We've already had several nights in the teens).
Old 12-13-2010 | 05:18 PM
PJ 3's Avatar
I had mine set at 2 hours and that seemed sufficient.
Old 12-13-2010 | 05:39 PM
cougar's Avatar
I run mine for 4hrs, but you know how warm it gets in the winter here.
Old 12-13-2010 | 05:54 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
i ran mine for 1.5 hours this morning (single digit temps but out of the wind) and the temp gauge had moved up. thats about all i ask out of it.
Old 12-13-2010 | 06:47 PM
92smokin blacky's Avatar
I just got a little timer at ACE hardware so i'm gonna start using it, but 2-3 hours should be enough
Old 12-13-2010 | 06:54 PM
i bought one too for the block heater. it was something like 16 dollars but the gf has christmas tree lights hooked up to it
Old 12-13-2010 | 06:55 PM
Bigfury's Avatar
Block Heater
Set mine to turn on about two hours before start up. Also I throw a moving blanket,from harbor freight couple bucks, on top the motor. Really made a difference. Before the block heater,alone, would melt the snow off the hood. It also helps warm the battery,auxility fuel filter. Try not to forget it. I've drove a couple miles to work until I remembered it was still covering the engine. Luckily it is stiff enough to stay out of the belts.
Old 12-13-2010 | 07:14 PM
The_Head's Avatar
This is something I should look into. I left mine plugged in all day today for no reason.
Old 12-13-2010 | 07:41 PM
JD730's Avatar
2 to 3 hours is all we ever ran them up here in northern NJ. We have a water heater timer setup to turn it on/off.
Not sure what I'm going to do this winter, truck's in a detached garage for the first time, warmer than outside, but I might set a timer for an hour to see if I get heat faster.
Old 12-13-2010 | 07:54 PM
rammin sammy's Avatar
Don't the block heaters turn themselves off when they reach a desired temp? and back on again when needed?
Old 12-13-2010 | 08:04 PM
dzl_damon's Avatar
no, they just get to a point where the heat they make is radiated off.
I usually only do 1 hour but I will do 2 hours when its below 10 or so.
Old 12-13-2010 | 08:06 PM
The_Head's Avatar
Mine really makes the coolant sizzle. You can really hear it.
Old 12-13-2010 | 09:03 PM
BearKiller's Avatar
I hear this all the time from people that should know better; it's sort of like the "full-time" 4x4 systems that "kick out at 30-mph."
No; there is no thermostat of any kind on a standard block-heater.
They are a simple water-heater element molded into an expandable rubber freeze-plug.
Old 12-13-2010 | 10:19 PM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
i agree on 2 hrs. look at the specs on the timer you buy, some are not rated for over 600 watts. some are rated at 1500 watts. i dont know how many watts our block heaters draw but my stupid ( sold ) 6.0 powerstroke had a 2000 watt draw and fried a few timers...
anybody know the draw?
