tic tic tic sound?????????
Old 05-15-2009 | 03:09 PM
mt250's Avatar
Anyone know what might be causing a tic tic tic sound from the front end at low speeds? have recently replaced brakes pads, tie rod ends, steering dampner shock, and pitman arm. I only hear it at low speed and seems the intermitent ticking is directly related to vehicle speed. at high speeds it is either gone or i just can't hear it over the engine. It only makes the noise while in 2 wheel drive, SWITCH TO 4X4 AND THE NOISE GOES AWAY. iT'S DRIVEN ME nutz. aNY HELP ON WHERE TO LOOK WOULD BE APPRECIATED.
THanks,
mt
Old 05-15-2009 | 03:20 PM
Cowman 5000's Avatar
check your hubs and axel u joints
Old 05-15-2009 | 07:45 PM
Diesel_Dawg's Avatar
If the noise is not present when the hubs are locked, I would think one of the locking hubs is the culprit.
Old 05-15-2009 | 08:38 PM
dieseldawg604's Avatar
i second the hubs!!
one of my hubs wasnt disengaging and made the same tic tic tic could really hear it when near a no post gard rail!!! cleaned and greased the hub and no more tic!!
good luck
Old 05-15-2009 | 08:57 PM
hey man nice name!!! hahaha
Old 05-16-2009 | 10:48 AM
ppiggppenn's Avatar
my guess is your brake pads jumping, .... you probably cleaned out the caliper and greased the slide surfaces so there's room for the pads to jump a bit. If so it'll stop when the debris builds up again.
Old 05-16-2009 | 03:44 PM
mt250's Avatar
THanks for the replies. I took the hub covers off and they look good and pack with fresh looking grease. But it sounds like diesel dawg said. guess i'll really take the hubs apart tomorrow and repack em and see if that does the trick.
Old 05-18-2009 | 05:51 AM
89D250's Avatar
I don't know, this might be an ignorant question but do you have rocks in your tread?
Old 05-18-2009 | 05:53 AM
89D250's Avatar
I don't know, this might be an ignorant question but do you have rocks in your tread? Sorry didn't see that it only happens in 2 wheel drive
blacksmoke
05-01-2012 01:02 PM
madhat
45
12-15-2009 07:13 PM
39b
16
12-14-2009 04:19 AM
megajoltman
19
12-04-2006 10:59 PM
kutch
11-04-2006 03:55 PM
Quick Reply: tic tic tic sound?????????
