throttle linkage
throttle linkage
where can I buy the ball lock for the ends of the throttle linkage? The local cummins shop don't have them,nor the part stores including napa. Thanks,
I bought the metal ones from cummins... great upgrade.
Here is how I fixed mine; I replaced the plastic ones using steel Heim joints I got from my local Specialty Fastener supply.
I got both the Left and Right hand thread so I could use my factory threaded rod, All of the hardware is metric.
If you look you can see a groove around the end of the threaded portion of the right side joint, this signifies it has the left hand thread.
With this setup there is ZERO slack in my throttle.
A drop of oil on the joints ocasionally keeps everything running smoothe.
Jim
Jim
cLAYH
02-06-2004 10:59 AM
