Throddle linkage adjustment help
Old 09-10-2024, 09:11 AM
nonrev's Avatar
This might help slot it the top of screw lines up with 2 on the left and 4 on the right
Old 09-10-2024, 09:27 AM
cougar's Avatar
That is exactly what I was wondering, if you had messed with the throttle lever. Which, that detail you left out. To be clear, with the adjustable link attached, does it idle too fast? If so, you will need to turn the throttle shaft in the IP one spline counterclockwise. After that you will need to adjust your idle stop and then readjust the adjustable throttle link. Lather, rinse, repeat as necessary.
Old 09-10-2024, 09:47 AM
Rug_Trucker's Avatar
I was going to put my ball in the other hole. However you will have to cut the plate/bracket for the TPS. I left it alone.
Old 09-10-2024, 03:58 PM
Firstgenforever's Avatar
Yes when I had it in the original hole it idled to fast but it was like that before I started Messing with it so I moved the ball cup linkage to the other hole but the
tv cable is now not adjusted right. When I did turn the throddle screw going into the pump on accident I was playing with it after I found out it wasn’t right I just turned the screw all the way to the right and stuck it back on
kctms
12-28-2017 05:33 AM
wbski007
10-23-2012 04:59 PM
smooth89
09-19-2011 06:28 PM
dandyalgleish
10-12-2007 11:49 PM
dandyalgleish
10-10-2007 11:58 PM
Quick Reply: Throddle linkage adjustment help
