For those with deep or double deep trans pans..
Ever consider going back to stock if you live in a colder climate? It kind of hit me on this crisp night and was wondering if it would be worth it.
2nd gen here - but i have a double deep and thought the same thing before buying mine. it gets pretty **** cold around here and i have not had any issues, nor have others with the deep or dd pans in the same area or colder climates. do it and forget about it.
Not worth the trouble. I really don't think you'd gain much, if anything by swapping to a shallow pan for winter. The added capacity of the deep pan is still an advantage in the winter...it just takes the fluid in the pan a little while longer to warm up. Considering that the trans fluid also runs through the cooler in front, as well as the engine coolant, I can't see it being a problem.
EverydayDiesel
11-11-2007 09:33 AM
texasram2500
05-21-2007 08:01 AM
MrKen
11-23-2006 03:19 PM
BigBlue
09-30-2005 08:27 AM
