Thinking of buying a 1st Gen...
...and have some questions. I'm keeping my orange Ford but plan on racing/pulling/etc... with it a lot more so I want a back up truck. I've already got the Ford (which I love) but figure why not try something else. Plus I figure I can pick up a 1st Gen pretty cheap.
1st question: About how much should I expect to pay? I'm figuring a 5 speed manual trans, extra cab, doesn't matter to me if it's 2wd or 4wd (although I'd prefer 4wd), single rear wheel, 3/4 or 1 ton.
2nd question: What years do the 1st gens span and what year was the extra cab introduced?
3rd question: I don't PLAN on doing anything crazy with it, but if I was to put about $3000 toward mods (not counting air intake, exhaust, or clutch), what would you recommend?
4th question: Are there any years I should avoid or look for? Anything I should be sure and check out while examining the vehicle?
Thanx for any help!
Thanx for any help!
welcome
1: price varies alot depending mainly on condition. 5000-8000 should get you a pretty nice one worth dumping money into. But you may find a deal if you look and somebody doesn't know what they're worth.
2:diesel first gens are 89-93, 91.5 and up are intercooled with 4 speed auto.
3DP stage 4 with a S400 based trubo of some kind should get you right around 400 hp.
4: They're all good. Pre intercooled can be upgraded with an intercooler(the first gen coolers aren't that good anyway) but the 3 speed with 3.07 gears is not a performance combo by any stretch. To change that will require some money better spent elsewhere.
A first gen is a great truck, and spanned from 89-93. The best years of first gen to find were the intercooled years, 91.5-93. 92 had the biggest, laggyest turbo with a 22 cm exhaust housing, and all the others being 18.5. The 89-91.5 non-ic trucks had a small issue, the head had 9mm injector bores, which made the head prone to cracking, 91.5+ changed to 7mm.
You can expect to spend between 3-8K for a decent x-cab 1st gen truck. And if u were to dump 3 grand in mods youd have a monster!! We gain so much from wrenches, and screw drivers its unbelievable. 60-80 HP with basic hand tools, n a dremel for one or 2 mods. Your most expencive mods being injectors, and a turbo.
Everyone has there opinion for injectors and turbos, but I would say a schwitzer s300, with a 14cm w/g exhaust housing is suitable for little over 400horse. As for injectors, there are a few options. But it depends on what u want to do.
Glad to see ya made it from Comp. D Elmo!
Yeah, I spend a lot of time here. You'll be happy no matter what year ya get. Go for a 5 speed if u look at anything pre intercooled. The 3 speed auto's kill any go fast wishes u may have, unless u drop a grand or 2 for an overdrive unit. Also I wouldnt be to concerned about the heads with the 9mm injectors, unless u go for big boost, and hp numbers. But they aint nuthin a PDR head cant fix.
...and have some questions. I'm keeping my orange Ford bit plan on racing/pulling/etc... with it a lot more so I want a back up truck. I've already got the Ford (which I love) but figure why not try something else. Plus I figure I can pick up a 1st Gen pretty cheap.
Thanx for any help!
Thanx for any help!
Thanx for the info fellas! Well, Looking on ebay, it seems these trucks are a little more rare than I thought. Would there be any issues you know of converting a flat bed to a regular bed? And how tough would it be to convert from an auto trans to a manual? Does anyone make a kit to do so?
There is a guy in the process of swapping from auto to manual right now. I think there is actually a tech article in the sticky on it, n someone with a 6-speed floating around. I dont remember which forum though. There r like 5 forums on the cummins, i attend 4 of them, i'll shoot u a PM.
Flatbed to regular bed should be relativly straight forward, unless someone did some fancy welding, n cutting.
So your over diesel stop? or is there another TDS? I used to be on STD, I mean TDS with my 92 ford IDI, but found a better forum for that!
U got a mean Powerstroke too, I have seen a few of your vids over on Comp D, great work! im lookin forward to see'n what ya do to a great classic 1st gen cummins ride!
Nobody makes a kit for auto to manual.
I just paid 7 grand for this truck... It's a 1992 W250 Clean inside and out! I knew the history on the truck and I must say I found a diamond in the rough... Go to http://www.myspace.com/Drifter0678 and click on "pics" It's got power stroke seats, Pac brake, fuel screw turned up a bit and a 12mm housing on the turbo. Future mods are as follow's. ASA intake, Stans 4" exhaust, new fuel pin, and ATS Tranny. Also a buck Stop bumper and re paint "can't stand black!" so going to Silver and probably Line X the bottom quarter panel... Sky Jacker 2.5 soft ride, if there is such a thing for these trucks lift kit I'm sure the list will go on and on as time goes on. I was thinking I was done sence my 04 has everything a guy could want on it, but this baby came along. Good thing I'm single again! You might be a diesel head if your wife says "you buy this truck, I'm going to leave you"... Where do I sign? Oh, it's got 172,000 miles on the ticker
deanhinsley1963
09-30-2012 08:37 PM
Riflemanusmc
13
05-12-2009 12:04 AM
