these are a PAIN
just installed the bendix mc. HUGE difference in the pedal. still not as good as id like them to be. i think im still going to delete the rwal valve.
Did you adjust the rear brakes? Are the antilock warning lights on? I would be real patient with bleeding them before I started deleting parts...Mark
I test all new master cylinders by plugging the line ports and filling them with brake fluid, then shaking it and moving it around as if it were in a moving vehicle. I have found the majority to be leakers. Just keep returning them until I get a good one. Beats installing each one only to find out that the cap will not seal.
I had trouble with the frame mounted rabs keeping light on, and did the delete/bypass, and brakes worked great ever since, could very well be the cause of your troubles, glad to hear you have had success with the master, good job!
Clarification on this comment along with all suggestions offered. About 6 months ago I battled all that the OP is battling with his brakes. Did the 3" shoes, larger cylinders, new booster, bled and bled till I bled! Swapped bleeders for speed bleeders so as not to suck air in as I was bleeding brakes myself. Adjusted the rear brakes by raising the rear end, spinning tires, and rotating the star wheel till slight drag. Finally deleted the RWAL valve and Wala! Awsome brakes! Well, 6 months later I'm noticing initial press down on brake pedal is lower and softer. A quick second pump and brakes are good again. I go to empty parking lot to go in reverse and stop 4x and rear brakes good again. I guess my question is can the adjustments on the rear go bad that adjustments are necessary as part of maintenance? Is the reverse and stop method as good as spinning tires and turning the star wheel w/ brake spoon?
sounds like adjusters are to blame, check brake inspection slots for excessive shoe movement, you can readjust to restore pedal, should not have to readjust, just guessing.
I forgot to mention along with new shoes and wheel cylinders I replaced every piece of hardware involved with the drum brake system, including the star wheel adjusters
jmccart
15
12-07-2006 01:59 PM
04ctd
10-23-2006 12:09 PM
Brambles
20
12-21-2005 06:09 PM
Gotlift01
16
10-27-2005 06:10 AM
