There goes another voltage regulator help.
So I just checked my alternator and it seems to be putting out the same volts on both contacts on it my dads truck one is higher then the other.
Is my alternator ******?
If you are referring to the voltage measured at both the small field terminals, with the engine running, it sounds like there is good continuity through the brushes and field winding, so that should rule out the alternator as the problem and point toward the voltage regulator or its circuit as being the problem.
That circuit is supplied battery voltage from the ASD relay, and the ground side is controlled by the voltage regulator. So, if you are not seeing any ground potential at one of those terminals, you need to look at the regulator. I don't have the schematic handy, but you can apply ground to one of the pins at the regulator and see if it "full fields" the alternator, or forces it into full output.
How would I apply ground to it all it has is two wires that are in a plug.
Okay so your saying there might be a fault relay at the heart of this problem?
I can't understand your situation from your description.
What voltage are you seeing at the battery --- way too high or too low ??
I have acquired a distrust for these ND alternators and the Chrysler regulator; I am un-certain which or both is the culprit, but these trucks have way more than their share of regulator problems.
My half-a-million-mile 1978 Chevy has never had a regulator fail (internal).
Likewise the two very high mileage Fords (external).
Numerous tractors, loaders, and such and never a regulator failure.
On the other hand, the three Dodge/Cummins trucks we own have had more new regulators than oil filters and we change oil frequently.
For example, the wife's truck lost the regulator one night, boiled over the battery, and shot both head-lights in less than a mile.
A couple weeks later, with the good blue Mopar regulator, it just quit charging.
Trouble-shooting that situation took out three more regulators.
I swapped on a known-good extra alternator and fixed it for now, but I don't trust it to stay fixed long.
Which is why I have been systematically converting everything to 110-555 Leece-Nevilles.
um well it keeps pegging the gauge every time it blows a regulator but I just found a broken battery connector on the ground my stereo has been going wonky today as if it's not getting enough juice so it turns off then back n off n you get the picture so I am going to buy a new regulator and battery post tomorrow n go from there.
One thing i've noticed during my ford crewcab build is grounds. The Ford has ground straps everywhere! between the frame and cab, frame and core. In fact there is one at each front cab mount and one at each core support. One from the cab to the hood, one from the cab to the engine. Seems like everywhere I look there is a ground strap.
On the dodge ?????????????????????????? i'm still looking for a factory ground strap between anything.
So I guess what i'm saying is I think ground straps could be the solution!
The relay's job is to supply battery voltage to the field. If there is batttery voltage there, as you had noted, the relay sounds as though it is doing its job.
I shorted out the FSS wire one day when I crimped the female spade connector down. Blew out the regulator right there. Think that's what happened to the precious one, too. My voltage is more stable than it ever has been, since I found the short in the harness over the booster.
darrenG
10-26-2005 10:39 AM
