Temperature Sender Location
I have been pondering the wisdom of installing the mechanical temperature-sender straight up behind the thermostat, like where I put mine.
To even get the gauge to register, I had to bleed off the air twice.
My puny brain got to puzzling on this and, if a little air-pocket is all it takes to give in-correct gauge readings, and this location is about as high on the engine as can be; so, considering these facts, should something develop a coolant leak, and the coolant level drop below the temperature probe, the engine could very well over-heat, and the gauge never have a clue.
Am I thinking right??
When I install the wife's new mechanical temperature gauge, I think I will look for an access port lower in the water-jacket, where it will be more likely to remain submerged.
What are you guys thoughts on this??
Thanks.
Thanks.
Way in the back of the head on the drivers side
I put my mechanical temp gauge in a connection on the top left (drivers side) of the head way in the back. Just barely clears the windshield wiper motor.
Reads anywhere from 160 to 180 degrees F when its warmed up, Bearkiller.
esde
06-04-2011 11:46 AM
cwgtex
06-30-2010 08:17 AM
95RAM111
11-11-2003 02:32 PM
