Takin' up the slack
Takin' up the slack
Rebuilt my Power-Lok diff this morning. The clutch packs were totally shot, a friction plate in each side had been cut through by the dished steel plate next to it. The friction plates next to the side gears were totally shiny, no facing left on them at all. All the slack in the axle was due to the clutch packs being worn so bad. This allowed the side gears to move too far out, which meant they were only meshing with the spiders at the very tip. Pics of this mess are in my photo gallery.
It was a pretty easy job, the worst part was lifting the diff back into the housing - that sucker is heavy! It's hard to stand the smell of the friction modifier additive too, it smells like rancid oranges. You get in big trouble if you try to soak the clutch plates in the basement the night before - better do that outside. Took me about 3 hours from backing in the driveway to putting away the last tool.
The truck drives much smoother now. I used to have to roll in and out of the gas very gently to avoid jerky shifts because of all the slack in the rear. Goes from drive to coast without a jerk now.
It does make it go much better, doesn't it Dave. Once you've done it once, now isn't so bad if you need to do it again. I just wish I had a Power-Lok instead of my Open Diff. Since replacing my Spider & Side gears, I can no longer get Posi out of my Brake Locks. I try and try but that stupid right rear tire just SMOKES. Starting to notice the tread depth is different from it.
Nuttymopar-
Thanks again for the link to Reider Racing, they were very understanding about my stupid mistake (I thought I had an open diff) and got me the right pieces in time for the weekend.
Hopefully once the POD's go in all 4 will smoke on mine.
Troutstrannysvc
01-22-2008 01:39 PM
3Sigma
09-07-2006 08:33 AM
