Tachometer 92' Cummins W-250
Old 01-02-2011 | 11:51 PM
Farmboy12357's Avatar
My tachometer doesn't work so what would have gone out on it? where's the sensor at and how do I replace it?
Old 01-03-2011 | 12:20 AM
Lucas1's Avatar
check for power check ground check all connection....then take it to somone who can check it if you cant find the problem..........or replace it.
Old 01-03-2011 | 12:25 AM
What is the sensor on it? The guy I bought it from said something about the magnets needing replaced or something?
Old 01-03-2011 | 03:08 AM
Lucas1's Avatar
on the front crank pulley i believe there are there is the magnetic pick up ...91 and later i think.from what i remember its on the drivers side right by the front of the oil pan
look in the sticky
Old 01-03-2011 | 06:27 AM
Onemoparnut's Avatar
There is a crank position sensor on the front of the engine. Make sure it is gapped properly at 0.050. Fill out your signature so it is easier to help you later. Is the truck stick or auto?
Old 01-03-2011 | 10:13 PM
Is it a factory tach or aftermarket?
Old 01-03-2011 | 10:23 PM
Factory
Old 01-03-2011 | 10:35 PM
Is it charging?
Old 01-03-2011 | 10:43 PM
The electrical system? Yeah it's charging
Old 01-03-2011 | 11:06 PM
Then the cps is working I would start checking the connections under the dash.
Old 01-03-2011 | 11:08 PM
okay
Old 01-04-2011 | 03:48 PM
Can someone put up a pic of where the tach sensor is because I cannot find it. I think all the connections are good.
Old 01-04-2011 | 09:38 PM
freight train's Avatar
The tach sensor? You should be looking at the crank sensor. It counts the revs via a magnet.
Old 01-04-2011 | 11:35 PM
Yes, thank you. It's the tach magnet. I was looking for the wrong thing and in the wrong spot. I found it. Now I just got to replace it.
Old 01-04-2011 | 11:36 PM
do they usually go bad. Im going to check the gap first.
