tach question
tach question
i tried hooking up a tach from my nissan gasser, it was a universal tach, so i hooked it up to the Grey wire with the blue stripe and it didnt seem to work at all, is there something with these diesels you need to do or buy for a tach to work in it
I got this to go with the $30/used ISSPRO tach I found on Fleabay. Easy install, been working great for a year and a half, solid, no probs.
http://www.egauges.com/vdo_indS.asp?...nsors&PN=R8912
It's basically just a crank sensor, probably same or similar to what was used on the 92-93 trucks.
This widget will let you use a gasser tach with diesels, http://www.dakotadigital.com/index.c...rod/prd128.htm
well on mine i just used a sunpro tach, i set it to 4 cyl. on mine i hooked it up to the factory harness by cutting and splicing, no problem reads from 500 rpms (idle) to 3000 ( full rev/out of gear)
Has anyone on here used a big rig tachometer? I have a local heavy truck wrecking yard that sells tachs for $20. Many styles and sizes to choose from? I wonder if they would work on my 1st gen Dodge?
