Tach Hookup
Tach Hookup
Is there a spot to hook the tach up to on the engine already or do I have to install something when installing a tach. Any recommedations on a tach would be nice. I was think ing of a pillar mount small tach in with a couple other gauges.<br>Thanks<br>Todd<br>93' 4x4 Just Getting Started!
Re:Tach Hookup
Firstly... Welcome Aboard!!! 8)<br><br>Yes there is a tach hookup on your rig. There is a 4 pin harness just above the steering column under the dash sort of behind the dash gauges.<br><br>Isspro makes a tach harness and tachometer to hook up to that existing connector and I believe you can get it in the 2 1/4" version for the gauge pods on the market.<br><br>If you do a search for this topic in this area, you will have more information than you need by others that have done the same thing.<br><br>Good luck..<br><br>J-eh
Re:Tach Hookup
I thought i'd ask this here. I've got a Dixco diesel tach thats supposed to hook to the alternator. Can I hook it into that factory tach wire and actually get a reading? Didn't want to burn it out by doing something dumb. Thanks Rick
Re:Tach Hookup
Being that the alternator pulses would be higher frequency, I am not sure that you could get it to calibrate properly to the engine speed. You could try it, I doubt it would hurt anything. THe tach signal is the Grey/blue wire I believe.<br><br>J-eh
Re:Tach Hookup
I ordered my 2 pod pillar mounted gauge pod from www.hotroddiesel.ca I got the Isspro Tach and Boost gauge.<br>Thanks<br>for all the info on this site guys its been a great help.
Re:Tach Hookup
Wildcat Diesel is another good spot, in Sask and supports this site. Give Rod a dingle and he won't steer you wrong..<br><br>www.wildcatdiesel.com<br><br>J-eh
Pacman400
01-05-2012 07:33 PM
TPilaske
12-03-2002 07:12 AM
