t.case rear output shaft yoke nut
What size is that sucker? I don't have a socket big enough and so I have to go buy the right one tomorrow. All I know is that it is bigger than 1 1/4"
Almost seems like it would be a metric size. It's not much bigger than 1 1/4" though.
Anyone know? I'd rather not buy the wrong one and have to make 2 trips to town, if you know what I mean.
I deperately have to change out my rear output shaft seal on the case. It's leaking REAL bad. like a quart and a half (or more) in 1200 miles.
It's times like that that I wish I owned caliper. Maybe I should go buy one of them little doohinkies tomorrow too if it's not too much money
Thanks in advance,
Rick
Thanks in advance,
Rick
When you put the nut back on it needs to be tight - over 200 ft/lbs. It is what keeps the speedo drive gear tight. Otherwise you might find you have either a non functing speedo or one that bounces. If you need the exact spec. post and I will get it for you.
Bob
Bob
id like to know what the specs are on both the rear input and front input nuts.....i just changed both my seals....there definitly tight but i dont know if there that tight....thanks!
SOOT4BRAINS
11-08-2007 04:52 PM
1stGenBikeHauler
01-25-2003 12:31 PM
