T Case/ Front Axle Problems
Last week I driving the truck and looked under it after I stopped. Gear oil was running out of the front output transfer case flange. I hopped under and grabbed the driveshaft. The front output was loose, I figured it was time for a rebuild.
So I get it out and tear it down. Found that the flange was loose on the output shaft. So I went further into investigation. Front driveshaft splines are loose, but not gonna cause a problem.
I dug far enough and found that when the front wheels are turned that the manual hubs enguage and turn the driveshaft. Sometimes the hubs don't release continually run the front output shaft of the transfer case.
Has anyone come across this before, or any suggestions?
Thanks in advance!
Glenn
Thanks in advance!
Glenn
the quick way to relese the hubs is after you take the truck out of 4x4 you unlock the hubs then put truck in reverse for a few feet and it should release the hubs incase they are stuck..
very very common in old ford 4x4 dana 44..
The biggest reason I am trying to diag this first before I rip it apart, is the closest major supply center is an hour away.
Thanks
Glenn
Got it all apart and the ujoints are seizing up. I am in the process of fixing that right now.
My second problem from the front axle enguaging all the time is the front output flange is now wore and loose on the output shaft.
Thanks for the help.
Glenn
coadman
04-11-2005 01:02 AM
