swapping VE44 for P700
I Know someone out there has taken off there VE44 and replaced it with a P700, is the 700 really a better pump?? what parts are needed to do the complete swap, right now mines a 93 with a VE44 and whats the best year P700 to use for the swap if I decide to do it, thanks guys, Wayne
your current pump is refered to as a "ve" . any dodge application p-7100 will work . ive done several conversions and its easier and cheaper to have a complete donor motor. the advantage of the p-pump is mainly more high rpm fuel. the ve has a broader powerband. in most cases i dont think its worth the swap.
You have a VE now. You're thinking of putting the P7100 on.
There's nothing wrong with your VE pump, I dont see a reason to do the swap.
The VP44 is the pump the 98.5-02 24 valve trucks have.
I'm with the rest, for that purpose I see no help with a P7100 inline pump.
The only benefit I see of a P7100 P-Pump set-up, over a VE pump, is the fact that it is lubricated with engine oil. So if you run out of fuel you will not damage/grenade your injection pump.
