Steering has a mind of its own
Old 04-26-2010, 10:19 PM
shaunbolton's Avatar
Bad U joints?
Originally Posted by bigredbrick
Front axle u-joints! Check them out then replace before you get yourself killed! One or more cups are froze up and when they rotate due to vibration and line up vertically with the axis of the knuckle/yoke then you got no steering - usually temporary until the u-joint rotates some more - if that makes sense
I'm not sure how u joints on the front axle would affect steering. unless the hubs are locked. When my hubs are unlocked the axle is not turning. Can you clarify this more for me. I've been having the same sort of problem lately. Thanks
Old 04-26-2010, 10:37 PM
torquefan's Avatar
The axle may not be turning, but the u-joint still needs to flex when you steer.
samsneeze
06-03-2009 08:38 AM
jeeptjstud
09-09-2008 09:46 PM
NorKal12valve
05-08-2007 08:42 PM
Quick Reply: Steering has a mind of its own
