Steering box woes
Old 04-17-2012, 08:59 AM
Jklawinsky's Avatar
Steering box woes
Since my AGR box failed and has been replaced. I have alot of problems with keeping the steering box tight. The 4 bolts holding it on to the frame bracket keep loosing up it seems. These 35's just seem to e putting alot of pressure on the box and bracket. I'm going to do crossover steering pretty soon but was wondering if anyone knows if there is a aftermarket steering box bracket like the old Chevys have? Also I know crossover steering will help steering obviously but it is pretty effective at reducing pressure from the box.
Old 04-17-2012, 09:09 AM
Crossover steering deletes the plate that attaches the box to the frame. that's the plus
Old 04-17-2012, 09:17 AM
Jklawinsky's Avatar
Thanks Brandon!
I didn't know that. I have borgeson shaft and AGR box and really fed up with the steering lately. You know of a good crossover article that shows how the box mounts without the bracket
Old 04-17-2012, 10:48 AM
The frame has holes in it to bolt the box directly to the frame, this was for 2wd trucks.
4x4 trucks to save money, dodge took the same standard box and mounted it out on a plate. When really they should have designed a different box for just 4x4 trucks that would bolt directly to the frame.
It's literally the matter of, removing the box/plate. Throwing the plate away, and bolting the box back to the frame in the existing holes, but you can ONLY do that if you're doing crossover.
Old 04-17-2012, 11:09 AM
Jklawinsky's Avatar
Yeah I did a little more research and i can't wait to get rid of that bracket. I found a support bracket for 2wd boxes that I'll probably throw on on too
Old 04-17-2012, 05:57 PM
enafzige's Avatar
The late '70's early '80s ram chargers had a support bracket from the factory. I scored one at a junkyard for $5 recently.
--Eric
Old 04-17-2012, 08:23 PM
Jklawinsky's Avatar
--Eric
I found a website that sells them new! 50 bucks a pop though
Old 04-17-2012, 09:12 PM
93-12Smoke's Avatar
You need this. It will reinforce the frame for the crossover. http://ramchargercentral.com/jungles...6dd137652514fd
Old 04-17-2012, 11:33 PM
Jklawinsky's Avatar
Do you know if he is a member on dtr or just ram charger? That looks like the cats meow
Old 04-18-2012, 06:38 AM
Jungle's Avatar
Eric on RCC did a nice how to on this topic.
Check out this;
http://ramchargercentral.com/article...ew;article=176
& this;
http://ramchargercentral.com/article...ew;article=175
Jim
Old 04-18-2012, 07:12 AM
93-12Smoke's Avatar
Jungle is a member here. Just pm him. Was a breeze to install.
Old 04-18-2012, 09:01 AM
Jungle is right there ^^^
Old 04-18-2012, 09:49 AM
93-12Smoke's Avatar
Haha, yes he is.
Old 04-18-2012, 10:21 AM
Jklawinsky's Avatar
Haha thanks fellas and thanks jungle for posting those write ups. I'm glad I came across this becauae without a doubt I will be going with that kit. Jungle, I will pm here in a week or two to get one ordered. Man am I ready to get rid of this bump steer
Old 04-18-2012, 10:44 AM
Jungle's Avatar
Glad I could help!
Jim
Quick Reply: Steering box woes
